Discuss Victron Phoenix Inverter 12V 2000Va Smart inverter installation in the UK Electrical Forum area at ElectriciansForums.net
hi all new here :) right so am upgrading my inverter set up in my work van i use this set up for tools and camping the new inverter going in is a
Victron Phoenix Inverter 12V 2000Va Smart what i am trying to work out is will i need to run it in to a 240v consumer unit RCD /MCB. my old ivereter just had plug socket on side i did run that with a rcd spur here is a link to what am getting Phoenix Inverter Smart 1600VA - 5000VA - Victron Energy - https://www.victronenergy.com/inverters/phoenix-inverter-smart
The neutral output would need earthing to allow the rcds to operate in the consumer unit.Not sure if the
inverter could produce enough fault current to operate mcb,s.
Regards,S
Exactly, there's not much point having a box full of MCBs when your inverter has electronic protection at around 8A. As for what you will achieve with an RCD, you have to check the manufacturer's spec re earthing the neutral, and decide whether you are effectively running a single load from it and can therefore leave it floating as an IT source, or whether there is an advantage in making it TN if powering multiple devices outside the van for example.
Reply to Victron Phoenix Inverter 12V 2000Va Smart inverter installation in the UK Electrical Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
Hi folks, I have recently had a 5kW Solis inverter and 15kW/hr of batteries installed. Everything is working fine, but I have some concerns about...
3 Phase Smart Meter EDMI ES -30 B Install I have a question regarding the potential replacement of my existing EON supplied ELSTER A1140 3...
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
