Discuss Volt sticks... in the Electrical Tools and Products area at ElectriciansForums.net
I have a Kewtech, and its great, never been wrong yet, but always check anyway. I mainly use mine to check lights are working when they have no lamps.
I'm going to buck the trend, I have one I bought from RSComponents but I'm not sure what make it is. It's black and it's called a 'Voltstick', I only use it about twice a year and it works fine, it's about 4-5 years old and still works with the original AAA batteries that came with it.
the best one i,ve used is a fluke pro230, has a notch in the end so you can identify a live cable in a grope
sorry, group
i used a volt stick for years, always spot on now i got a west 166 which lights up and beeps but its always best double check, seen a few sparks check with just that and then lose the end of the driver in a giant flash and a pop.
Reply to Volt sticks... in the Electrical Tools and Products area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
Megger MFT X1 or Fluke 1664 FC Is there any difference? Which one will you go?
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Hi, I've got a light with a ceiling rose in the kitchen. While rectifying some faults in the house I came across to the light and measure Neutral...
5K
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
