Discuss Voltage recorded when switch is off? in the UK Electrical Forum area at ElectriciansForums.net
A
abnjim6
I am installing ceiling fan and when the ceiling wires (two) are tested for the presence of AC voltage and the wall switch is OFF, I read 50 VAC. When switched on the VAC reading is 117 VAC.
I am using a T5-600 Fluke multi-tester in the "V" position.
Should I continue with this installation and risk a shock?
Why does this tester read 50 VAC when the wall switch is in the OFF position?
Thank you.
James
There is a pretty obvious solution to this one. However, if you are not sure whether or not you should continue then I suggest that you don't.
You will put yourself at risk if you have not had the necessary experience in dealing with electrics.
You have been warned......
if the voltages are as you stated, there is a problem which needs sorting by a qualified electrician. if we gave you ( as a non-electrician) advice which resulted in you being electrocuted, we would be at fault. call in an electrician.
Abnjim6, take no notice of these people, the true cause of your problem is the pixies at your local electrical makers, pouring too much of that electricery stuff into your cables.
i would get in touch with them and demand they stop
Emm I take it you are in the US if this is the case your 117v is fine your 50v is induced ac pick up because you are using a multimeter but if you used a voltage tester nothing would register
Hop I am right about US or it egg on ones face lol
Reply to Voltage recorded when switch is off? in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Cathodic Protection Station with Switching Power Supply for Buried Metal Structures Benefits of the Switchmode Cathodic Protection Rectifier...
Hi there, wondering if anyone can give me some advice please. In my kitchen I have a cooker switch with a plug socket which I believe is on a...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
