Discuss Water heater thermostat in the UK Electrical Forum area at ElectriciansForums.net
WallaceP
So i have been having to odd problem when i used my electric boost for the hot water in my own house, sometimes it would not control the temperature correctly and effectively turn into a kettle. I don't use it too often so its never been a priority. My plan was to get a new thermostat tomorrow so I will check the size tonight. I found it was a 7 inch stat that had been installed, and thought it seemed a bit short. When I checked the depth of the housing I found it should be 11 inches. I think this is most likely cause of my problem, which could have resulted in severe burns the way it is currently set up.
This is something I would never have thought to check over in an inspection but now i am thinking i will look out for. Has anyone else seen this? I am wondering how common a problem this is.
The stat shouldn't be tight to the bottom of the stat pocket so it should be less than 11 inches.
If it's a horizontal element fitted in the side of the tank then it should normally be an 11" element with a 7" stat.
As mentioned above any new stat should incorporate a safety cutout device.
Reply to Water heater thermostat in the UK Electrical Forum area at ElectriciansForums.net
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I have a customer who has an 18" thermostat in their water tank which periodically requires resetting. I went to replace this but am unable to put...
The unit only heats water using the programmed boost and when pressed in the 1 2 or Cont boost function. I have checked the off-peak time which...
