Discuss what cables will I need for this please in the Home Media Centre Forum area at ElectriciansForums.net
000aces000
Hi I'm looking at the 8 series samsung tvs & I am wanting to wall mount flush as possible, are brush plates a good idea?
I have sky hd, blu ray ps3 what cables?
The gap on the wall brackets are around 3 cm is this enough to plug the tv in?
I want to future proof in some dirt of fashion as its getting plastered in
Also I have a old oval shaped bt junction box in my hall them cable going from that to a master socket, I need to relocate this directly into living room, I will be drilling a hole from outside in the cable is long enough, what connections do I need to use & j am wanting to fit another socket at the other end of room, what cable would I use and again what connections, is this a slave ?
Thanks for any help
Regards
You'll need co-ax for the aerial and HDMI's for each of the devices you're connecting. You can get right-angled connectors which have a lower profile.
As for the BT issue, I'd get them in to do it, it is more involved than you may think!
Reply to what cables will I need for this please in the Home Media Centre Forum area at ElectriciansForums.net
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
I have just removed a rather expensive CD system from a house. I did explain to the customer that I thought it was worth quite a bit, but they...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
