M
monkee
Having been to a call out to a faulty socket the customer said that thay had received a shock when thay tried to grab the metal part of the device which was class one.
I said, I can see you have had some work done and I take it the consumer unit was upgraded due to the extra circuits kitchen etc..
can I see the EIR please, she said she did not get one because the electricain became ill ok I will carry out some tests to the socket..
so I grab my socket tester plugged in and no earth great start so I removed the socket found three pairs of 2.5 in red and black i then proceed to split and test back from
the board I could not get an R1 R2 reading so I tried method two R1 and Rn ok but no R2 I scratched my head but that was it no earth back to the board.
The customer had added a flex to convert the single socket in to a double and had pinched the live wire with 3.5 again I showed them this but they said why didnt the
fuse blow well if there was an earth path it would have blown but as it had not got one thats why and when u plugged in and then touched it you became the earth path
thay said that the prevous guy had trouble with readings in this area and kept moaning about something, then he offered to add in a single socket were there once was a
fuse spur which happened to be the next leg in the circuit again untested with no earth . This is my ironing socket she said I always use this one since he offered it.
so what would you do his name is all over the consmer unit and he is part P do you tell tales or what, he missed this circuit out when testing for the board change
what would you do... grass him up, phone him or just be professional and put it down to a bad day we all get them
Part P is it working I think that sparks are forever being rushed and pressurised your thoughts
grey skies grey faces...
