Discuss whats the best way of joining 25mm cable together in the Australia area at ElectriciansForums.net
Has the cable been ruptured accidentally or are you intending to use two lengths that you have available to you. How and where will the cable be installed and what type of environment.
thank you for replys on joining 25mm cable. the cable is single core thermosetting 70 degrees same as meter tails and it has got damaged want to mend rather than replace all of cable. i am able to pull a little slack. what method would you recommend. If i use crimps would it effect the amp rating of the cable.
thank you for reply on joining 25mm cable. the cable is single core thermosetting 70 degrees same as meter tails and it has got damaged want to mend rather than replace all of cable. i am able to pull a little slack. what method would you recommend. If i use crimps would it effect the amp rating of the cable.
thanks for reply would using copper tube crimps effect the amp rating of the cable i have not used crimps on this size cable before and where not sure if would be okay thanks
Rumrunners solutions will do the trick or, as suggested previously an insulated Henley block could be used. Whatever solution you decide upon I would recommend that, if you can, you secure each side of the point of the connection as where you can pull through some slack you are likely to get some "pull back" over a period of time and securing the joint in this manner will act as a strain relief on the actual joint.
the best way(not the quickest) is a weak back ferrule ,tools needed blow torch ,materials tinmans solder ,flux ,heat shrink,next question-how old am i
yours benji
Reply to whats the best way of joining 25mm cable together in the Australia area at ElectriciansForums.net
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
Hi I'm installing two new sub-mains. I need to parallel some of the supply cables. It's the main incomer in 5 x 25mm, with 5 x outgoing 25mm...
Hi, I'm about to reroute cables and sockets/switches from the ceiling down to the socket height after insulating a wall. I understand this will...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
I having been trying to make a cart wheel chandelier for my wedding in July like the one in the photo attached. I have 31 lamp holders in mason...
