Discuss What’s this? Is it a? in the UK Electrical Forum area at ElectriciansForums.net
FatAlan
Trainee
Supporter
Sort of thinking is a big old isolator switch (the lump on the right). TT supply, tails split to small garage DB with supply continuing to main house from this switch. Circa Pete999?
A switched Fuse, in the ON POSITION looks like an MEM one or similar, one fuse only ( Hunt for Red October) give me a fuse.
There were a couple of very similar-looking products by Bill Switchgear under the 'Crown' name. This one probably does have four 15A ways, but it could equally be a 60A switchfuse and look basically identical. It think Bill might have used the same metalwork for both.
The equivalent MEM product that Lee shows is either a Memspel or Memspan (one is insulated, the other metal, never could remember which is which), or maybe a Memsplit. In the days before the term 'consumer unit' was popular, there were distribution boards a.k.a fuse boxes, which might or might not have an isolator built in or separate. Then there were switchfuses which had only one outgoing circuit. In the middle were the popular units of two or three ways, which were sufficient for a small installation or a part of one, which were sometimes called splitters.
These later 4-way versions are like overgrown splitters. I think some even had two ratings of fuseway, 2x 30A, 2x 15A often used as 5A, so they would provide for a ring, a cooker and two lighting circuits, or whatever.
Always gratefully received if generally complete...
Reply to What’s this? Is it a? in the UK Electrical Forum area at ElectriciansForums.net
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
