Search the forum,
Discuss Why did 2 holes in my outlet turn blue in the USA Electrical Forum area at ElectriciansForums.net
need a bit more info. e.g. pics? some cable made in the 60's (over here anyway) reacted and produced a greenish slime, which tended to leak out at outlets.
OK. I'll try to send pic. Thank you
Any chance that there has been water seeping in to the back of the socket?
In any case the socket should be replaced, and if the cable is degrading that as well.
If it is only the socket (e.g. water damage) then that is a fairly easy DIY change if you have the knowledge, but if you are unsure in any way we would simply advise you to get a local electrician in to check/fix it. If you have any doubts about the advice/quotation from them then come back for more advice and one of our USA members such as @Megawatt is likely to be in a position to advise.
Thank you very much for your advice. This all makes sense to me now. I am calling electrician and someone to check my roof right away. I wasn't sure if roof was leaking in the next room in very small area along the crown moulding. I can't thank you enough for your reply!
Yes
it may not be water ingress. as suggested, it could be the pvc and copper in the wires reacting.
A few hours ago I was eyeing the few bottles of Brewdog Mr President I have left and trying to weigh up the balance between drinking one there and then or hoarding it for a more auspicious occasion on account of the (£&%%'_*$&#!s having stopped making it ?
Spooky.
In the end I decided against the Mr President and had one of these instead
Quite nice, but not really hoppy enough for my taste.
And talking of hoppy - how come there was no rabbit in my shipment?
Spooky.
How strange!
I gave the Freedom 7.5 out of 10.
The rabbit likes a beer also. Nothing too fruity though.
The signs were there by post #10.
I thought, post #10 offered, an incisive. and. informative's opinion, relative, to the discussion. admittedly, the last IPA was a bit strong. and citrusy, obviously.
Punctuation check - all good.
No, It's not. a comma after "thought" and "offered";
full stops after "incisive" & "and"; comma after "relative";
I’ve never seen blue outlets but I’m going to say it’s the material inside the outlet which makes it a tamper proof receptacle
back in the 60's some cables (in the uk anyway) had some plasticiser in the manufacturing mix. this eventually led to reactions with the copper, producing this green goo which leached out of the cable ends onto terminals and hence dripping out of outlets. a bit like the green on a church copper roof before us Scousers weigh it in.
And an article with a couple of photos:
Horror stories to tell young electricians around a camp fire :)
Reply to Why did 2 holes in my outlet turn blue in the USA Electrical Forum area at ElectriciansForums.net
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
my wall outlet's buttons broke off and got a bit confused as all the wires are brown .what are these 2 wires for ? Thank you
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
My daughter asked me to replace a standard outlet on her porch with a GFCI outlet. We installed it correctly but were not able to get it to work...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician State Laws for Electrics and Electricals may differ on a state-by-state basis. American questions and answers can be found in our UK electrical forum.
