sew333
Dec 31, 2018
76
Poland
Hello. Today first time something tripped breaker in my house. I mean i was sitting on Windows 10 desktop ,like always and i hear BUM from fuse box. And power go down. Pc turned off.
I have that pc almost 1 year and something like that never happened. I think there was not circuit overload,because all devices was off,like tv,washer etc. Only pc was on. And nothing get damaged. Anybody have clue why it happened?
To turn back power again i change breaker to up of course. And its fine again.
PC:
Aorus AD27QD
AORUS PRO Z390-PRO GAMING
Aorus 2080 Ti waterforce stock
2x16GB DDR4 GSKILL XMP
9700K STOCK
Seasonic TX-750W TITANIUM PLUS PRIME
Never happened with that pc in whole year. Also pc is stable during full load etc.
Today i just browsing internet and power goes down with tripped breaker.
Pc working like before again. Weird any clues?
Or maybe pc is faulty? I mean some part and it caused that once?
All other devices in house was off,like tv,washer,lights.
could be just a nusiance trip. happens now and then. keep an eye on ---, seeif it holds. or if it trips, keep a record of when and what was connected.
I figured out. Bulb get burned in bathroom !!!!LOL and that caused trip breaker. So pc is ok if its running?
[automerge]1598730713[/automerge]
Can led bulb trip breaker if get burner?
[automerge]1598732624[/automerge]
it was halogen bulb i ask my mother. So no led bulb
it's very common for a bulb (especially halogens) to trip a breaker when they fail.this is due to the high fault current generated at the time of failure. something to do with ionisation of the gas in the bulb. basically the breaker sees this excessive curent draw and trips, as it is meant to do.
Breakers (MCBs) are prone to trip as they are very sensitive to short circuit currents.
Generally,
Faults between:
1. Live - neutral = MCB
2. Live or neutral - Earth (CPC) = RCD/RCCB
Somebody from reddit say this to me"
You just confirmed your main (not just a circuit breaker) was tripped while using your computer. This should virtually NEVER happen unless you are fully overloading your main breaker (which by your description you are not). Computers and bulbs shouldn't ever blow a main breaker, just the breaker they are on. If your whole house breaker tripped, either something is wired very very wrong in your house and can cause a fire or shock (kill) someone OR your main breaker needs to be replaced which definitely needs an electrician to fix."
That shouldnt trip main breaker ,when bulb get burned. And i am worried. He is right?
a blown lamp can cause a chain reaction. 5A fuse then 16A breaker, and a RCD. or even a 63A breaker. it's all down to which device sees the fault first.
I ask my mother. She told that 2 breakers went down. 1 one for power for sockets in house,2 for lighting in house. But not RCD. So its normal?
PC:
Aorus AD27QD
9700K STOCK
It’s hard to say but I can assure you that it wasn’t your PC. Check the breaker and see if it’s warm to the touch which it shouldn’t be. If it is it has a load on it that your not aware of
Why i lose a power circuit too when a bulb blowed on a lighting circuit?
@Sew33 To be perfectly honest I don’t have a clue. Does your breaker Trip when 1 light blows in the same light or does a breaker trip when any bulb blows in any light fixture ?
yes two small tripped breakers near each other. One for lights in house,second for power in wall sockets.
why power in wallsockets go out and lights at the same time? its as expected?
RCD ( that biggest on left ) not tripped.
When a breaker trips it will take power off lights and receptacles. It all depends on how the electrician wired it up so yes that’s not unusual
So it was normal when power in whole house goes off and lightings off too?
I’m not saying that you are loosing ALL power I’m just saying that a lot of electricians put lights and some receptacles on one circuit. Are you saying that your main breaker is tripping?
No,the main was not tripped. But two small circuit breakers. One for power in sockets,second fo lightning. So it can be expected/or normal when halogen bulb wil blown?
Poland
Why my breaker tripped?
Electrical Appliances & Whitegoods Forum
Thread Tags
sew333,
sew333,
