Discuss wickes multi-way G digital dimmer help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
sarabear
I have some very old wiring and wondered if it was poss to wire this remote switch into existing ?
at the moment can only get one light to work and neither dims ?
i belive it does need to be updated,
is in my future plans
the wires coming out of the switch in the lounge are red,blue and white
only advice i can gice is to get a sparks to come and have a look. if you post your location ( approx. area) sure one of us will be close enough to have a look-see.
am in Brighton, do have a sparks friend, that told me needs re wiring, just saving at mo, :(
thought wud b ok to put new switches up in mean time :p
Reply to wickes multi-way G digital dimmer help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
