B
BillyTheSparks
YO!!
Right senario I have, Main house is to be demolished on Monday.
There is a new Temp meter and supplyboard (hager 17th board with 1x 63a MCB on one RCD) via a SWA to feed the house for the rest of the week. And 1x 63a MCB on the other RCD to feed the static caravans own C/U Again via SWA.
Plan is to remove the house SWA on Sunday and re-route to the portacabin/site office so that demolition can take place first thing Monday.
All good so far.
Now the problem being that next to the static caravan there is a touring (towable) caravan to act as a bedroom for the kids.
This second caravan is not phyisically attached to the first and has its own CU.
The frame of the second is metal and is earthed to its CU.
The second will be supplied from the first via a commando socket outlet on its own circuit.
The first also has a metal sub-frame and an earth rod. At the moment it has a 30mA RCD unit which can be changed to a split load 100mA Main switch / 30mA RCD (from the old house).
So the question being should the second caravan have it's own earth rod and RCD protection wired from a non RCD protected (or from a 100mA RCD) way from the first?
Or could it be bonded to the first via a 10mm or bigger Earth cable?
Any help would be great
All good so far.
