A
Andrew54
I am a potential customer for PV panels and I am wondering about the cable run from invertor in loft to meter and consumer unit. I want the finished job to look neat, and it's not going to be easy. What about going down from the loft inside the cavity wall?
It is a dormer style roof so there is no easy route from loft to eaves. It's a semi detached so only one gable wall. Meter etc is in the cupboard under stairs halfway along this gable wall, but with a large house extension built at the side so cupboard is roughly in centre of the house! The original cavity wall is no longer an outside wall and this cavity could make an easy route from cupboard-under-stairs up to loft.
Will a cable in the cavity comply with regs? Obviously you can't get in the cavity to clip the cable.
I was thinking of putting in some sort of rigid conduit myself, then the electrician can thread the cable through easily. To make it easy I was thinking of using a rigid plastic pipe of 32mm, maybe sink waste pipe.
Would this be ok? Would it comply with regs having a cable inside such a conduit?
Your thoughts gentlemen please.
