Discuss wiring practice with industrial installations. in the Canada area at ElectriciansForums.net
C
chris07
Im a electrician, and work in domistic installation.
I've been ofered the job of rewiring a office building on a power station, when i've looked at the old installation the old lighting circuit has been partly removed and seams to have been wired as a lighting ring circuit with 2.5mm twin. Is this the normal wiring practice with industrial installations.
Cheers
Chris
Absloutely not!!!!!!!
Only ring allowed is normal BS1363 socket outlet ring main, and CPC as a ring on a radial BS1363 circuit with high protective conductor currents.
definitely not lighting, industrial or otherwise.
good luck with the job
Definitly shouldnt be a ring, but 2.5 may have been used because of voltage drop if its a large circuit or a long way from the DB. Possably 2.5 could have been spec'd for lighting circuits as some health authauritys I have worked for do this. 2.5 for ANY lighting circuit and 4 mil for sockets. I dont know how they expected someone to get 3 lots of 2.5 in the terminals of a light fitting though!
I have come across lighting circuits done in rings , twin and earth, loop in system, 1mm, on a newish property, i was dong a p.i.r at the time, confused.com !!!
Reply to wiring practice with industrial installations. in the Canada area at ElectriciansForums.net
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
