- Feb 10, 2012
- 2,264
- 2,984
- 4,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- If other, please explain
- Running own small electrical company.
I have an EIC from a customer for a domestic property, dated Dec 2005, which covers the installation of a new consumer unit, to bring the installation up to date (at per the regulations in force at that time, stated as 2001 amended to 2004).
There are two socket circuits, would you have expected them both to have been protected with an RCD?
There are no RCDs installed in the consumer unit.
The certificate has the box ticked the "Presence of RCD(s) for supplementary protection ..."
The test sheet shows the protective devices as 60898 for all circuits, and just one socket circuit has an entry in the RCD columns, which I think is for a lone RCD socket by the back door (for use outside).
I have the impression the customer was misled at the time about what they were being invoiced for, but being a rental property did not actually inspect the work. The invoice is slightly vague (perhaps deliberately so), and which is why I want to check what the regs would have required at that time.
