Discuss Wiring Up Outdoor Light in the DIY Electrical Advice area at ElectriciansForums.net
maybe I'm not reading this right, but it does just sound like you have a spare switch that you want to wire to a new light. Is this correct?
Sorry to sound a bit negative ( Don't say anything Tel...) but you seem to be doing quite a bit of electrical work at your house. Are you sure you are up to it? Are you testing the changes to the circuits afterwards?
Lighting circuits should be easy to look up on Google.
New project. Yes testing everything afterwards. Just wondering the best way to do things.
Hope you are not using the 'bang' test.
Have you not Googled "light wiring diagram" ?
first find out if there is a neutral at the switch. then the black wire goes to the blue and the red wire goes to the brown, and if you can be bothered, wrap that pesky green/yellow round a screw.
SpoonTrusted Advisor
New
i've got a heavy wiring diagram i can send him.
Haha the bang test hasn't ever happened yet. Sounds fun though, but I wouldn't like to try.
Got a few diagrams and done lots of lights before, just want it to be neat from the switch.
The switch im connecting it to is the one in my first post pictured.
It's good advice Tel...... At least try and research the project first before asking.
haha send him that then..... :)
Edit: Ok OP. sounds like you have.
I'm assuming the two way part was added at a later date, as there is sleeving on the switch wire but none on the strappers.
Doesn't look as if there is a neutral at the switch.
So you need to run line and neutral from an existing light, either to the switch then switched live and neutral to the new light, or to the new light then run a line and switched live to the switch.
You could even run a single sheathed wire from the light that the switch controls to the switch, then link the line between the two switches, then take some T&E from the switch to the new light.
so.no neutral at switch, so you need to feed a neutral from the existing light to the outside light and a switched live from the spare switch.easiest way is to runn a new T/E from the light permanent L and N to the switch box , L into switch2 and out to light, and N in a terminal block/wago to the light. earths taken as read.
I cant see it mate, sorry. Rubbish work comp. Get "The proxy server isn’t responding"
Cheers. Yes i added the 2 way last night and will sleeve today.
Another option would be to replace the existing T&E used for the line and switch live with 3core &E.
You could use one core for line, another for neutral and the last for switch live.
Reply to Wiring Up Outdoor Light in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
