Discuss Auto Electrician - Purchased a Property that requires a complete rewire. in the The Welcome Forum area at ElectriciansForums.net
Just a quick note to say Hello.
Recently purchased a shell of a property in the Midlands that requires substantial refurbishment.
I will be managing the whole project from the start to finish and was hoping to find some good advice and information with regards to the connection and rewire process.
I'm not planning on doing any work myself, I just want to make sure I get it all done in the right order safely at the right price.
Any advice and tips would be greatly received. Looking forward to meeting some of you in the forums.
Kind regards
where in the midlands? the north midlands is on my patch. anywhere north of stafford. down brum way you have sparkycus.
Thanks Tel the property is Just North of Junc 5 of M6.
I take it that I should sort the Plumbing as best I can before the electrics then.
My first problem on the Elec is the connection. I've been digging around this forum to find some info on the cost/time for connecting a meter as it appears that the Elec meter has either been stolen or removed by the DNO / Elec provider.
I've attached a Pic, I'd be grateful if anyone could shed some light on exactly what is required for starters.
I know I need to get a new 17th edition Consumer Unit and complete rewire, however some historic info on here states that I will need the rewire in place and dead tested before the Meter can be replaced?
Thanks for your comments and advice. http://s25.postimg.org/iwk4cwyun/IMG_0591.jpg
I would consider installing a small temporary board with just the single light and a single socket connected in order to get a connection to the network.
Once you have the connection, you can install the rest of the installation as and when circumstances allow.
You will need a system in place that is certified as safe before the energy supplier will fit you a new meter and energise. However, that doesn't need to be the whole proper final installation, a 'builders board' should suffice, so have one fitted first to get working power on and then go from there. You need to have a design for the finished property for an electrician to work to in order to get the closest to a likely budget - so drawings of rooms, lights, switches and sockets, what's going on in bathrooms (showers/extractors/towel rails etc) and then some idea of a finished kitchen layout. We need to know what the heating system will be and where its being installed. Also think about things external to the building like outside lights, sockets, sheds, garages and so on. It doesn't necessarily all need doing 'in one hit' but the bigger the picture, the more cost effective the solution. And seriously, if Tel is offering, I'd be calling!
a bit too far for me as he's down brum way. right on spartykus's patch.
Excellent advice many thanks.
For the DNO to provide a new meter, the sparky will need to provide a builders board with a TT earth and a test cert will all the dead tests completed.
If it's a refurb, and not an actual building site then they'll often turn a blind eye to the TT in my experience.
That's rough. There's little chance of damage to the sheath or neutral under these circumstances. Especially if the intake is already indoors or a basement, where are you going to put a rod safely out of the way except for a 'proper job'.
Not round here in my experience!
Thanks for the advice Gents. Anything in particular I should mention/ask the DNO tomorrow when I call them regarding the Meter?
Not around here, UKPN and their predecessor EDF are a bunch of little hitlers in that respect.
I once had them refuse to connect a supply as the main bonding wasn't in place. The gas wasn't due to be installed until a week later and the water was a blue poly pipe with a brass tap on the end fixed to a fence post outside.
I showed them that there were no parts to bond but he wouldn't listen!
Reply to Auto Electrician - Purchased a Property that requires a complete rewire. in the The Welcome Forum area at ElectriciansForums.net
Good day all, I'm writing from the Commonwealth of Dominica (NOT Dominican Republic) where we have single phase 230V, 50Hz. I'm managing a...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
