Discuss Suggestions for mounting in the UK Electrical Forum area at ElectriciansForums.net
S
Scott Harman
Hi guys, I need some suggestions. I have a job next weekend in which the customer has asked for outdoor sockets to be mounted on a steel fixing coming from the ground and I'm stumped with what to use?
Any help?
if the steel is already in situ, drill it and fix socket with 4mm bolts, washers, lock washers and nuts
i did one for a water feature socket. just banged 2 lengths of unistrut into the ground. 4ft. below ground.2ft.above.it's still there 4 years later,
Knock about 6 foot of unistrut in and connect an earth fly lead to it - the socket can be TT then :) Only kidding before anyone goes off on one. Daz
Reply to Suggestions for mounting in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi, I'm going to be installing an outdoor socket, have no problem with the outdoor/socket side, but when bringing the internal end or the SWA...
Hi all, Figured I'd come straight to the experts with this one because I don't have a great deal of electrical experience. I'm a designer at a...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
