Discuss New DB install with old wiring in the UK Electrical Forum area at ElectriciansForums.net
All,
Just need an extra bit of help and information from what I have heard and have a bit of knowledge on.
There is a project to install a new DB but not replace all the old cabling.
An extra circuit will be added with new colours.
With this my understanding is that once complete and all relevant labels and testing but with this is there a regulation or conformity to replace all old cabling and equipment as the board was upgraded from circa (1980)
Everything tested ok but due to a replacement DB does this mean the cabling and equipment may be required to be changed within 3 years??
some help and knowledge would be great .
regards,
All,
regards,
Where did you get the information from which made you ask these questions fella?
You are upgrading a consumer-board and as long as you testing proves that the reading meet the regs, all is fine, especially the ZS reading of circuits. In other words the new consumer-board is pointless is the circuits are not to the standard because tripping times and other aspects, is the purpose of the upgrade.
relevant labels should include the one that says " some silly colours mixed with sensible colours; colour blind sparks beware. all new cables are grey in the dark".
i worked with a colour blind sparky, on the jobs with numbered multi core cables didnt make a difference lol
Reply to New DB install with old wiring in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi everyone, newly qualified spark here I went to a job earlier today where the fan was not running on after light had been turned off. Whilst...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Just looking to see if anyone’s had a similar job or has any other ideas. Got a consumer unit to upgrade, the current one is fitted inside an...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
