L
Lucien Nunes
No, not the neutral or live! The negative side of the 5V or 12V DC output. You would be checking to see whether the incoming earth connection in the IEC is carried through to the DC output. If so, then there is no reason why the case of the unit should float up to some arbitrary AC voltage, therefore you have a fault which you must find. If the earth is not carried through the power supply unit, then it is legitimately floating and you can solve the problem by earthing the case.Earth pin just inside the transformer and the other on the neutral pin
If any doubt remains, the power supply units should be subjected to a standard 'PAT test' to ensure their integrity.
