C
chrisgc
Hi
I have a checkbox (CCB1), it does the continuity and insulation checks BUT how do I do the Loop and RCD tests with the checkbox which does not have these facilities on?
I have read that you should have a dedicated circuit to do the loop and rcd tests.
Can someone please explain in more detail please?
Instructions not very clear so a walkthough guide would be most welcome.
Chris
Just install a dedicated, non RCD protected socket next to your CU and label it for test purposes only. As long as you test it with a recently calibrated meter first to prove the readings then you can use it to prove your meter.
Need to double check readings with a calibrated tester at regular intervals though, make sure they havn't changed
Hi Lenny,
How comes I have to use a Non RCD socket??
I thought it has to be a socket which is RCD protected?
Chris
Calibration Checkbox CCB1
Tags Tags
calibration
chrisgc,
chrisgc,
