Discuss Electric shower fail :( Gainsborough deluxe 10.5 in the DIY Electrical Advice area at ElectriciansForums.net
Dear all,
I'd be grateful for any advice.
It's a Gainsborough deluxe 10.5 fairly old.
I had an intermittent problem when the water wouldn't heat a couple of times. Solution was to turn the water off and on again a few times.
Now it fails but turning the water on and off doesn't solve the problem.
The pull chord works IE the light still comes on, and the water comes out when I press the start button. But no hot water. I tried twiddling the temperature dial, full cold, full hot. Water pressure is OK, at least the same as it's always been.
I can get a new motor for about £100 but I'm wondering if there's a cheaper solution. And I enjoy fixing something rather than binning it if I can.
cheers
Bin it... No matter how much youd rather repair it (i prefer to fix things too) the uphill struggle against our throw away culture just isnt worth it.
Cheaper - maybe not
More cost effective - cirtainly
th
no hot water thermal cut out have gone .
It is worth checking if the thermal cut out has gone but then you need to know why it has gone before you replace it. the space is limited but the mounting is simple.
Another possible solution is that the connections have overheated and now no longer allow full power to the shower but just enough to operate the controls. Check for heat damaged cables in the switch and inside the shower (and possibly at the consumer unit) if you are competent and careful and ensure the power is switched off before working on anything.
Thanks for your reply. Would the Thermal Cut Out fail like that. I mean would it fail intermittently.
I've had a look inside and there is no sign of overheated wires. No scorching anywhere !
If you do buy a new unit altogether, please come on here and tell us how shoddy the quality is, how dodgy the case seals are, and how flimsy the knock-outs for cable entry!
th
This is what happened to our shower got one from an online supplier £10 or about bit fiddly changed it worked ever since. Don't forget to put the plughole in or cover up in case you drop the small nuts and screws.
Thanks for the tip. Plug in place. Will test today, cheers
Dear all,
I put the continuity probes across the TCO and got a signal. So I guess it was OK. Since the TCO was wired in ( I can't get it out ) I'm not sure if it would have given me a false positive.
I mean to say, the TCO might actually be faulty but still giving me a positive reading. Stuffed if I know.
So I got a new shower engine £80 from tradingdepot.co.uk. Cheapest I could find. Even eBay was £95.
At least I won't need to drill any new holes. Should be a straight forward job.
When I swap them out, I might investigate the old one just for curiosity.
Cheers for all the advice.
Reply to Electric shower fail :( Gainsborough deluxe 10.5 in the DIY Electrical Advice area at ElectriciansForums.net
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
