- Nov 23, 2018
- 68
- 64
- 93
- United Kingdom
- Other
- If other, please explain
- Electrical technician currently working for a service lift manufacturer.
as some of you know my background is as an electrician in the RAF mainly working on 3 phase machines including generators. When it comes to meter calibration they are always done and any meter found to be out of calibration is quarantined until it’s been done.
My new employer seems much more cavalier. My supervisor was told 3 weeks ago the Fluke he’d provided was about to go out of calibration at the end of November. Here we are on the 13 Dec and I’ve spent the week fault finding with it on 690v equipment still out of calibration.
Now for the type of tests I was doing I don’t need it to be pinpoint accurate. Is there voltage or not? Is there continuity or not? Despite that I’m still uncomfortable using it right now.
I have to admit to not really knowing what happens when they go for calibration. Is it also a safety check for instance or is it purely making sure it reads correctly? Is it standard as a civilian to calibrate your equipment or is it more one of those things you should do and probably will when you get around to it?
I’m trying to gauge how hard I want to push this with him.
