R
Rodrayner
Hi,
We are building a new extension which is the opposite side of the property to where the current mains in and fuse box is located ( which are on the opposite side of an external wall ).
The extension will be a new kitchen with an electric oven and hob, utility room with washing machine / tumble dryer a garage and upstairs a new bedroom and en-suite. So i guess what i'm saying is there is quite a bit of electrics going in and some of it such as the oven & hob will have a decent load.
Between the existing fuse box and new extension are several solid concrete floors with the new extension also being a solid concrete floor.
To get round all this and make life easier i was thinking of having a trench dug outside from the existing fuse box down to the extension and then run new cable into the garage and put in a second fuse box. The total distance being 35 mtrs. At around 15 mtrs along the trench from the fuse box i need a trench anyway for drainage services so the plan is to lay the electrics into that trench if i'm allowed to, it will include soil pipe and blue MDPE water pipe.
Can anyone give me an idea of what size armored cable i will need, i have read suuggestions that it needs to be around 16mm but want to ask the experts.
Thanks in advance.
Thanks in advance.
