Discuss Nest Thermostat 3rd gen in the UK Electrical Forum area at ElectriciansForums.net
Sat22
Hi, I am installing a nest thermostat 3rd generation. It is a conventional boiler with only 2 pipes going down. Pic attached. It’s controlled by a programmer upstairs and a thermostat in the hall. I’ve taken the old programmer off. And I have these wires. Pic attached. I wired the heatlink, connected everything got the green light but heating wouldn’t come on. Any ideas? Is it because the old thermostat is still wired in?
Looking at it, I think you have the wiring wrong on the nest heat link.
The thermostat should be removed and safely terminated, often the original wires can be used to power the nest unit.
There will also be a wiring centre, often near the hot water tank, some changes might need to be made there.
Thank you ??
The original thermostat needs taking out of the system - or - you preserve the wiring and use it to power the nest thermostat +12v and mount in it's place (all in the instruction book).
Generally speaking, the Nest Hub will just piggy-back off the existing 2ch wiring into the old time clock.
Thank you ??
I've no idea what wiring diagram you followed to get to that but it's a long way off! You appear to have a 'Y' plan heating system, there is a Y plan diagram provided in the Nest manual.
Thank you. All done. Great forum
Glad we could help! And, enjoy your Nest (which I would have to say, being a Nest installer and personal user!)
I have a nest 2 learning controller with nest link. I have been offerered a nest 3 learning controller thermostat without a heat link. Could I just add the nest 3 to the system and use the heat link that i have?
Reply to Nest Thermostat 3rd gen in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
