A while ago I replaced 3 fluorescent lights with 3- 2'x 2' led panel lights. In one room I installed 2 panel lights that were on 2- 3 way switches whereas one had a dimmer, and in another room I installed 1 led panel light that was on a regular single pole switch dimmer.
The dimmers weren't working properly so I bought 2- 0-10v dimmer switches and installed them....or tried.
First I had to install another set of wires for the new switches so the dimmers would work.
I first wired the switch to the room that had the 2 panel lights, then I installed the switch the other room.
The problem is this. Without the dimmer wires connected to the switches, the switches work fine. Once I connect the dimmer wires, I get no lights at all.
Can someone tell me what I'm doing wrong? I tried all ways of wiring them but nothing works. Thanks for your help.
