TheConduitKing
Trainee
Nov 9, 2020
86
39
1,193
Northern Ireland
Hey everyone, how's it going?
I built myself a practice wall in my garage so that I can get more training in at the weekends from stuff I do in tech and on site.
The difficultly is drilling holes in the boxes and getting them centered and uniform.
Here is a link showing the drawing I've been following and how messed up my boxes are. ?
This is the boxes I've been using:
I have only now found out that you can get them with knockouts. ?
But the problem is that they don't have any side knockouts.
Any advice on how I can measure the boxes to get the holes centered and in the same location across them all? In college the holes where already drilled and they didn't show us how to do it.
The LAP box isn't suitable for conduit entries even though you could probably make some with a holesaw it will be tricky as that type of box is prone to shattering. The Tower box won't have side entries due to the face plate fixing lugs so you are probably better off with metalclad boxes which will have entries to all sides.
Reactions: TheConduitKing
Yup lol. Learned that the hard way.
Couldn't they just place the knockouts above the lugs on each side? That's where I've been drilling with limited success.
Surely there has to be some way of doing it. I'm guessing it's not a common way of doing things.
You can drill the Tower type boxes, they're made of a softer plastic to the normal surface box.
And they don't have the T&E knockout weakspot at the back of the box, which is why yours have shattered.
That's a good shout. I'll get those from now on.
But then how do I get the side holes all the same. I'd just dvide the length of the box in half to get the center point and do the same with the depth.
But that would put me where the lugs are. So do I just divide the length again to get into the corners?
This is what I've done so far
If I was wiring a garage with surface mounted wiring in PVC conduit I'd just go for metal clad boxes.
You need the midpoint of the space between edge of the box and central lug.
And low enough in the box so you can't get your fingers down the back of the conduit against the wall or board.
To get all the boxes the same, stack them all up against each other and mark a line across all of them.
Example of side position below, nicked from link below that,
I would use metal clad, your entries are all over the place, like your over saddle well done.
Thanks mate. That's very helpful. I'll give it a go and report back!
Gonna give what snowhead suggested a go and see how it turns out.
"like your over saddle well done."
Thanks! Took me a couple attempts because I wasn't keeping it straight over my knee and it kept warping. Got it eventually though!
Need to redone my 90. It's slightly off.
Reactions: 7029 dave
TIP, get some friction on the tube by rubbing it before you pull your set. (it warms/softens it up)
Aye, that's what I've been doing. But it's so cold in my garage that the conduit ripples when I bend it. But I am using heavy gauge pipe with a heavy spring.
So it's probably just me. ?
Good Good
Just follow the lazy Youtube sparks and use flexi conduit on everything. I've just finished a garage extension and did it in 20mm galv. Good fun but had to borrow a Hilmore and die set from a mate as I can't justify investing in that kit yet.
On similar note, patresses compatible with MT2. I got what o thought were ones that are MT2 compatible (according to the MK sales bumpf) bit can't see where to knock them out for toffee, any got any advice for interfacing surface patresses with MT2?
Product; MK 2-Gang Surface Pattress Box White 30mm - https://www.screwfix.com/p/mk-2-gang-surface-pattress-box-white-30mm/16168
lister, you need abs box.like this. (don't think screwfix stock them).
YT2 knockout in top and 20mm conduit knockout in bottom.
They're the MK ones we buy or the Schneider ones
Northern Ireland
Help with Surface Mount Patress Box Drilling for Conduit.
Electrical Course Trainees Only
TheConduitKing,
richy3333,
