Discuss Need help doorbell wiring! in the UK Electrical Forum area at ElectriciansForums.net
Aarthur66
I live in an old pier and beam house. We recently had to have our ductwork redone and around the same time our doorbells stopped working. We have two doorbells. After a lot of looking, I was able to find the transformer under the house. The way it is mounted I could see if getting knocked around and the hvac techs putting it back wrong.
wondering if I am just wired wrong or if the transformer has actually gone bad?
pictures attached and thanks so much for your help!
It appears that the red goes on the load screw and the other wire that’s connected to the same screw needs to be hooked to the 16 vac to 30ac screw
I tried that. No luck. When I touch the lv wires at the doorbell, I can see the chime move, but it doesn’t seem like it has the juice to strike.
I added three photos showing the front doorbell wire color, the back and the chime. From the transformer, I can see which wires are directionally running to the front and the back. Hoping with these pics someone can point me to the correct wiring configuration at the transformer.
Have you actually measured the voltage on those 2 wires
Reply to Need help doorbell wiring! in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
Good Morning need some advice please. Yesterday went to change a light fitting in hallway. There are two ceiling lights in the hall controlled by...
