E
E_Jon23
Hi all, just wondering if anyone has a preferred brand of outside LED flood light (30watts with PIR sensor) Replaced a dud Screwfix brand jobby (LAP) like for like a couple of months back and the thing packed up before Christmas. I've been asked to source the replacement this time around and just curious to what people recommend.
Ansell seem to be as good as any of the off the shelf ranges.
Reactions: buzzlightyear
I have tried hi sec, faulty, niglon, faulty.
Now gone on to ansell, over Xmas started to put up some from toolstaion time will tell.
I put a 10 quid amazon jobbie up at my house 6 years ago and it is still going strong , its a pir light so only comes on periodically so not left on for hours and hours, Think is Lepro
got a Ansell 30watt at home, been in 5 or 6 years. no problems. cost about £45.
I've had to replace a few Ansell, my wholesalers ended up sending their entire Ansell floodlight stock back to Ansell as the failure rate was so high
Did they start to flash and then end up really dim?
When replacing them they where just pretty dim if I recall, had several others for other jobs that under wholesaler instruction I sent back as faulty, even though brand new and still in the box. Also took down working floods and replaced them when on same jobs.
I've had bother with pretty much all floods I've supplied be it Ledvance, Luxna, Elex, Luceco, Ansell. Have a house with about 20 Ledvance floods fitted and reckon only reason I've not been back to change any is they next to never turn them on (which begs the question, why are they even there!)
Reactions: pc1966
Recommended brand for outside flood light
Lighting Forum
E_Jon23,
