- Dec 9, 2010
- 7,461
- 817
- 1,688
- United Kingdom
i have a board which is protecting one side with 100A main switch, and the other side is being protected by 100A double pole rcd.
can i get another 100A rcd and put in as main switch which will cover the side un protected by rcd.[h=1]MEM/EATON 100Amp 2 Pole A100HE 100 Amp 30mA Double RCCB Breaker 100A RCD/RCBO[/h]
making this board 17th compliant then.
there is plenty of spare ways in this board so if i can get another 100A 30mA main switch and then mem mcbs for the new circuits, seems easiest than changing board ... trev
