Discuss 16amp b type breaker for oven. in the UK Electrical Forum area at ElectriciansForums.net
J
julianacb
Hello all, excuse my bad grammar spelling etc. today i had the people from building control around to sign of my cu change
at my house,here is my question. My mum had her oven changed a little while ago and it has a design current of around 10.5 amps, the old fuse protecting was a 40 amp wired in a 10mm t+e, i have since replaced this with a 16 amp breaker and put connecters at old cooker switch and a blank plate. I done this as section h of osg states you can do this and dont need a switch if the circuit breaker is to be used as one. The inspector told me this is not Good and my interpretation is wrong. And i need a local isolation switch. I want to know what others opinion was on this he also said the oven is not fixed equipment? If im wrong fine but how do i remedy the situation its a double box do i just put the old cooker switch back on. I did do a little search before posting but could not really find what i was looking for. Any advice greatly appreciated!
And another reason i queried is that an electrician that i worked with done a kitchen extension and all appliances were done this way, but the fuse box for extension was actually in the kitchen, is this more acceptable or still not good practice?
it's always good practice to provide double pole isolation for any item of fixed equipment. as murdoch said. an earth fault will take out an RCD, so isolation of both L and N is recommended.
Hi Julian,
I've looked at many threads on local isolation and functional switching etc etc and there seems to be differing views, but the main theme seems to be that it is pretty bad practice not to provide local ioslation and in your case it probably doesn't comply with BS7671 (see below) because a MCB is not DP:
Page 45 OSG (ii)
ISOLATION
"The device must switch all live conductors in a TT system and all line conductors in a TN system."
Probably best just to put the 45A DP cooker switch back on :wink_smile:
it's not just that, happy. if the cooker had a N-E fault tripping the rCD, it's much easier to isolate the cooker with a D/P switch than leave a RCD that might also supply sockets and lights off till a spark can attend.
The switch is not required for isolation.
It depends whether you think emergency switching is required for an oven.
and in your case it probably doesn't comply with BS7671 (see below) because a MCB is not DP:page 45 OSG (ii)
ISOLATION
OK for TN, then. MCB, that is. Section 537 & Table 53.4.
Yep.
Why do people keep quoting the OSG instead of the actual regulations?
Hi Julian,
Page 45 OSG (ii)
ISOLATION
Thanks all for replies nails are in the coffin
probably rcbo's? but my limited knowledge is in line (no pun intended) with other replies.
now..
i`v seen this in renteds...where the only means of isolation for the cooker has been the MCB..
i thought it was crap then and i think its crap now....
this kind of install is only performed by them offering the cheapest of cheapest quotes...in fact in my mind it aught to be made a requirement to have a means of local isolation for such equipment...as on the 2 previous occasions where i have come across this..the dis-board was in the cellar below the kitchen area...
really poor...
I always fit an isolator switch for any appliance in kitchens...mentioning things going faulty and catching fire tends to sway most of them to my way of thinking...
Though lost one job as the clients wife was doing the interior design on a rented property and "didn't want those ugly switches on show" and they "all have to be in the back of the cabinets hidden out of sight"...no chance...he saw the point, i think she threw a fit as I've heard nowt since sticking the quote in weeks ago....
Got a job on tomorrow...re-lay a cooker supply....as previous owners rejigged the kitchen, put in a gas cooker and their spark just extended the ring for the cooker igniter and turned the old cooker/oven supply into a socket with random spur....not what I was hoping to find...was hoping it was just the usual cooker outlet plate previously swapped for a single socket...
I really hate crawling under newish build house floors (no room to move as the builders backfill them with crap and ends up like being on an assault course)...and I have to lift laminate in a cupboard to cut a hatch (Though owner is ok with it getting wrecked if thats what it takes to get access to the floor below..says he'll get a carpet if needs be for the cupboard so one saving grace)...'kin hell....this is going to be a LONG day tomorrow....still work is work...
Sorry, just checked my definitions. I thought of 'live' conductors as including neutral, but realise 'line' does not include neutral!
Yep.
I guess its because BS7671 is pretty scary and reads like a law book! I should have said 537.2.1.1, but seeing as though that says it doesn't need to be DP, we'll just say 'It's good practice so just do it' :D
Commonsense would tell any competent electrician to provide a means of local isolation to fixed equipment. It certainly wouldn't tell him to remove any perfectly sound existing means of isolation....
If you're not competent to do otherwise, you'd be a fool not to follow BS7671. What i mean by ''Competent'', is being able to stand up in a court of law and successfully argue your departures are technically sound and safety has not been compromised etc...!!
Well yes obviously you would be a fool not to follow the regs and like you say if you get dragged into court your goosed. And yes it wasn't really the most helpful of things, but it is a fact.
well, if following regs. meanss drilling into a RFC in the wall, i'd be wary. LOL. :furious3:
In itself maybe, but BS7671 is also part and parcel of other ''Statuatory'' Regulations so in effect you could say that in most cases BS7671 is statuatory by default of other regulations....
Reply to 16amp b type breaker for oven. in the UK Electrical Forum area at ElectriciansForums.net
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi there My old oven broke just in time for xmas😭😭😭 (murphys law) Ive picked up a new one which is rated at 16amp. The old oven came off an...
(Trying again, as picture didn't post first time) Hi, I'd be very grateful if anyone could help me here. Below, I've pasted a sketch showing how...
