Discuss Cannot get RCD test to work? in the UK Electrical Forum area at ElectriciansForums.net
I'm completely at a loss to understand what you're saying here. A bit back you're backing his method when it was pointed out (calmly and respectfully) that he was carrying out the test wrongly now you appear to be backing up what I said but only to get "a dead accurate reading"
Why would you not want a dead accurate reading?
I suppose really its a 'live' accurate reading. A 'dead' accurate reading wouldn't be great for a RCD test..
Sorry Trev, couldn't resist... just trying to lighten the mood!
well happy hippy you need to revisit the job and do what trev has said ...
disconnect load side and test at load side .
prove the rcd . take it from there.
take a spare if its a long way to wholesalers
I see what you're getting at but it's the correct way to carry out the test. Forgive my ---- retentiveness
Honestly that's cool. I seemed to of ****ed everyone off in this thread tonight. I gonna go watch Moto GP highlights and shout a the TV instead :)
Well you haven't done that to me so don't worry about it MM, it was nothing but a discussion from where I was sitting.
Enjoy the Moto GP, is Valentino Rossi still riding? Obviously you can see that I know three tenths of bugger all about it but my brother rates him very highly.
Was IR testing carried out through this RCD?
Glenn!! You're going to have to go back through the thread!! I did all tests and gave all results... Zs, IR, Continuity of CPC, pi R sqared, E=MCsquared and the meaning of life are all in this thread somewhere... Just look!! ;)
I'm off to finish watching the film now...
cheers for all the input guys.
Do I remember rightly that RCD testers abort the test if the voltages induced by the test (relative to the CPC) are too high?
I know it sounds rediculous but make sure you have a good connection where you are testing, I have found that if testing an rcd, say at a light fitting, it can make it not work properly if you arenot holding the probes on tight enough. Just a though....
Oh and make sure you have your leads plugged in the right holes on your meter, I did that once, can't remember which was round they were but it wouldn't trip the rcd as much as I tried.
Marquez is the boy at the moment. Rossi still in there, even Edwards and Hayden still going.
so in other words you shoved 500V through the RCD....
Thought RCDs were good for 500V apart from RCBOs on which you have to remember to disconnect any functional earth? If the RCD has been killed, wouldn't that result in a failed test rather than refusal to test?
may just not test at all....
personally i think theres either a lack of understanding about how to carry out the test competantly from the OP (hardly surprising)
or theres no continuity of CPC someware......
if theres any exposed pipework nearby the OP could prove the no continuity of CPC easily by connecting the earth croc to extranious whilst testing the RCD.....if it lets go then i would dare say its a CPC thing....
Try testing live (load side) to earth only(neutral and earth probes)
Did an rcd spur work out cheaper than fitting an rcbo at the board?and where did you site it?Above the ceiling?
What film are you watching?
Schindlers Fist?
Womb Raider?
Snow white does seven dwarfs?
School of cock?
Gangbangs of new York?
Here Now go and calm down your getting all heated under the collar lol
I have fitted RCD spurs mid point on light circuits for people when doing work and never had a problem to date, I would think there's something more simple going wrong here such as leafs wrong way over on MFT....
Back to your old ways then Glenn.. for a brief moment I thought it looked like you were becoming an adult.
Bit exhausting to keep saying it, so I'll give up after this... but have another read of the thread.
well...it would be nice to see some new ways eminating from your direction...
but it`l be back to trying to work out how to wire a bell no doubt...
have you not considered that you may have disturbed the CPC someware....probably whilst trying to put fronts on..
and it would be refreshing if you actually took on board some of the advice given as well (from me & others)...this would include the bottom sentance at #73...
rather that being....somewhat selective with your highlighting.....
just a thought mind you....take it or leave it...
haha you getting a bit annoyed their GLENNSPARK mate , dont worry am sure a few of your trolls sorry buddies will be along to back you up anytime now
Saw it yesterday Marques wins with Rossi right behind him in second ,good race , got out on my Blackbird afterwards ,,
Yeah, it would have been nice to see the race order myself thanks!! I'll let you off as you own a 11XX. I still got mine (98 Carb model), although it has been reduced to all weather use now :)
Yes definatly, I reckon it is that, but it would seem that many would just rather assume that OP cannot test correctly.
well come on...
what are we supposed to think when he comes in asking how to wire up a bloody bell
or how about the classic fail that was the dis-board change without any pre-testing...anyone remember that one?
oh and by the way before you decide to start...i`m not on my own in regard to this either....
i said before that the OP would be better shadowing an experienced electrician for at least a year before carrying out any more work on his own...
i still stick by this....
I had a 97 carb model, I now have a 55 plate one , but I much prefer the carb model , nice and smooth power control , Had a look at the VFR12 but I hate it ,rather keep the BB...
I had a think about this today and I think the op has the feed and the outgoing side the wrong way round , on the RCD spur ,,Just a thought,,,
harsh perhaps, but a clown - never. glenn's probably forgot more than a lot of members on here have learnt.
I have a problem getting rid of bikes (have 5 at mo). I had a 09 800 VTEC which was supposed to replace the bird but it was no where near as good.
Whilst I am not saying I agree with the Glenn about the OP of this thread, is it right that people can come on here, asking professional people trying to make a living ridiculous questions that even most apprentices would know the answer too? There is a very good reason why the DIY board was created.
Reply to Cannot get RCD test to work? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
So, I was messing around yesterday with some old testers I have laying around to see if they still work I found my dads old Robin MFT and noticed...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
