Discuss 110v site lamps at 240v domestic in the UK Electrical Forum area at ElectriciansForums.net
Hello,
I have bought some site lighting with 110v plugs to rig up in my shed workshop which has a 240v domestic supply. Obviously I can use a site inverter but I would like to avoid this. Is it just a case of rewiring and fitting 240v halogen bulbs? Some help would be greatly appreciated. Cheers.
The 110V GLS lamps we have in the stores last about an hour at 240V, but can only be switched on once or it will blow the second time. Light and heat output are tremendous.
To the OP - if you rewire and change the bulbs then surely it is a bit like Trigger's broom!
Reply to 110v site lamps at 240v domestic in the UK Electrical Forum area at ElectriciansForums.net
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hello all, I hope you're all keeping well. I have a question regarding insulation resistance testing. Whether doing a single circuit IR test or...
Hi all, just looking for some advice about getting into site installation work. Currently 32 yo, 1.5 years qualified gold card in electrical...
Hi all, Testing question for you. I'm currently testing an existing domestic installation. The wiring is about 20-25 years old. We have rewired...
