Discuss 125a 3 phase pat test equipment in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
im hoping someone here can help me, need to find out how to wire a 3 phase 125a connector to a normal 13 amp plug for use with a pat tester. my boss says you need to 'daisy chain' it, but he cant remember how its done. been trying to find a diagram on the internet but no luck as yet so thought id try on here. any help is much appreciated.
thank guys
You could make one but for the cost of parts you may as well buy one as in #2. If you want to make one link the line terminals together in the triple pole plug and connect the live of the 13A plug to them.
Reply to 125a 3 phase pat test equipment in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi Hope anyone can help Can someone give me advice on how to connect up a 3 phase to 13amp adaptor lead for carrying out PAT testing on 3...
