Discuss 1960s v shaped light fittings in the UK Electrical Forum area at ElectriciansForums.net
Yea i got an electric shock from it this morning trying to take the picture. Is this something I can do (remove the brown and black with the power off) or better for an electrician? Feel slightly out of my depth now so going to contact a sparky today ?It does look like a jack plug socket connected to a live wire, that is dangerous. Isolate the power and disconnect that brown wire then cut them both off, that switch should be replaced.
The switch is in the same room as the light, i think he may have used the jack point to connect an old radio as i found an old radio with a jack point in the loftThat could be nasty. Disconnect that brown and chop it.... and the black.
Mains voltage at that jack point, when light on.
Is the switch in a different room to the light?
Some sort of indicator in series with the fitting, eh?
I found similar at a place I re wired a few years back. Jack on the switch that is
Reply to 1960s v shaped light fittings in the UK Electrical Forum area at ElectriciansForums.net
