Discuss 2 Rcd's? in the UK Electrical Forum area at ElectriciansForums.net
H
HorridToe
I'm thinking of having a new fuseboard fitted. The existing one has 8 fuse in it and is boxed in. The 2 electricians who have come to quotesay i need a board with A main switch 2 Rcds and 8 circuit breakers. the board will not fit in the boxing. My friend has a board with 1Rcd and eight circuit breakers. could i have one of those fitted?
Having just one RCD is a non conforming and poor way of doing it, the reason for 2 RCD's is so you dont lose all power due to one fault.
Like Lee says a new unit comprised of RCBO's (combination circuit breakers) instead of "standard" circuit breakers provides a solution as you now need no seperate RCD's, did neither of the "electricians" suggest this?
I know I'm unusual but I try to upsell RCBO's to everyone
I think that for size the ''fuseboard'' with main switch and RCBO's is the smallest available in width.You will have to have a look at each of the manufacturers dimentions and see if you can't get one to allow spare ways for future additions. although could be slightly more expensive using RCBO's is the best way as under fault conditions only one circuit is tripped off.
As above You can fit a RCBO board which means every circuit is on its own individual RCD. Its more expensive than a Dual RCD board but the boards are smaller so will probably fit into the space. The electricians should have discussed this option with you. I normally advise installing a RCBO board as this minimises disruption if there is a fault. Just that one circuit is disrupted rather than loosing half the house.
I Cover Glasgow so get in touch if you want me to come out and provide a quotation.
Thanks for the replies. I tol the electrician I was trying to keep the cost down so maybe thats why he didnt mention the Rcbo option. I will ring him in the morning for a price cos if it fits I will prob be cheaper than rebuilding the boxing .
Reply to 2 Rcd's? in the UK Electrical Forum area at ElectriciansForums.net
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
So here is the thing Rhere is an old MEMSHIELD TPN+E Board that is pretty mich obsolete. The only place that sells their breakers would be Ebay...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
