M
Mr Curnow
1- To start off we first check the tests leads for damage.
2- Next test between Line and Neutral to see if it's live.
3- Turn off the supply, place the warning sign on the lock, lock it.
4- Keep the key in your pocket.
5- Next test [Line-Earth] [Line-Neutral] [Neutral-Earth].
6- Prove that the tester is still working by using the proving unit.
Is this right? Will I pass by doing this?
