Discuss 3P RCD Socket 4 pin or 5 ? in the UK Electrical Forum area at ElectriciansForums.net
Any pointers on the best place to get a 3P 16a IP44 4 pin socket with integrated RCD?
It seems that most places have 3P & N 5 pin now, online search seemed a bit fruitless other than dodgy eBay stuff!
Socket is for a heater and extension that doesn’t require a neutral, just thought it would look neater with it all in one box with an interlocked switch or is it just easier nowadays to put up a separate enclosure for the RCD and trunk a standard red wall socket out the bottom?
Didn’t really want to fit a 3p & N RCBO in the board due to room. Got 2 radials to go on the left, a 3 phase ramp on the right, this socket and it would be nice to leave 2 complete 3 phase circuits spare.
Should we just go for a 5 pin interlocked RCD and change the plug on the end of the heater?
I can’t see that Hagar do a 3 pole rcbo without using an add on and stealing another way.
£400 might be stretching the budget a bit, but thanks for looking.
I tried CEF and they said they only had IP67 not IP44 and they weren’t compatible, sorry if the dumbness is annoying but the last time I messed with 3 phase sockets they were made of metal and had brass plugs with securing rings!
Surely IP 67 would be better than IP44.
I
IP44 plugs will fit an IP67 socket, but will obviously only meet IP44.
The difference is that the IP67 has a locking collar.
This is an IP44 plug in an IP67 socket, it's SP, but the same applies to TP:
Reply to 3P RCD Socket 4 pin or 5 ? in the UK Electrical Forum area at ElectriciansForums.net
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
I was off duty, but this was a nice collection all in the same place: The 5 amp and 15 amp are obvious. The 4 pin one? 3 phase? It has Red B and...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
Hi, leading on from my question the other day about running the 3 phase compressor off my 8.5kW generator I have since got my hands on a 240v to 3...
