Discuss AC isolation switch? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Colin33
Instead of using the standard rotary isolator for the inverter, is it acceptable to use a standard 100A switch within the consumer unit? It's DP, can be locked off, and will obviously be clearly labeled :) Anything wrong with this method?
For some reason most isolators are the rotary type, but I'm not sure quite why they became the dominant choice as any other type of switch that meets the requierments for an isolator (contact clearance, etc) and can be padlocked off should be fine.
Isolator needs to be adjacent to the machine it is controlling.
Reply to AC isolation switch? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
