Discuss Access 2 Tade Careers in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Ok so would I be right in saying that as well as doing
EAL VRQ Level 2 Certificate for Domestic Electrical Installers
City & Guilds 2382-10 Level 3 Certificate in the Requirements for Electrical Installation (17th Edition)
City & Guilds 2392-10 Level 2 Certificate in the Fundamental Inspection, Testing and Initial Verification
City & Guilds 2391-10 Level 3 Certificate in Inspection, Testing and Certification of Electrical Installations
City & Guilds 2377-12 Level 3 Certificate for the Inspection and Testing of Electrical Equipment
I would also need to do the
2330 AND NVQ3 2356 or just one??
thanks Besim10 for your help :)
To be a qualified electrician you will need both
ok so what you guys are saying is to work in the industry as an "electrician" you need C&G 2330??
what do you need to do this ?
I'm currently on the access to trade careers "professional" electrician and now a bit annoyed to find out about this C&G 2330 not being on my course.
could I do the 2330 while still doing my access course? And if so when would be the best time to do this during the course, or after??
any help would be very much appreciated, im still kinda confused as to what i need to have in the industry; from what i understand the access course is kinda skipping a step by not having the 2330? confused :S lol
any help would be much appreciated :)
Also would like to know what exams etc are in the first week :) if any one can tell me :)
Doug, you don't "need" the 2330 to work in the industry as an electrician. I have spoken to NICEIC and they have said that I will be able to work legally under their scheme provided I have my 17th edition and have work that they can inspect. The most important thing seems to be experience and the 2330 does give a certain amount of that, but there are other ways! As far as I know you need your 2330 and 2356 to be on the JIB scheme but this isn't fundamental to you working as an electrician. Please somebody correct me if i'm wrong!?
You are correct.
The 2356 is a Log book based on onsite assessments so if you are not already working in the areas needed to be assessed in order to achieve the NVQ then you are not going to get it.
Hi,
No disrespect to anyone with my following comments - just want to get things into perspective.
You don't need anything to work legally as an electrician - the requirement is COMPETENCE.
What the 2330 gives you, that a three week 'wonder course' doesn't, is the fundemental basics and theory, along with practical work, to help you on the way to being COMPETENT.
You can take all the shortcuts that you like into this trade but, at the end of the day, it's you that has to be happy with your competence to do the work that you undertake and you that will be asked to prove that competence when the fire engines have been to a job that you did and you're up in court (god forbid!)
If you're happy calling yourself a domestic electrician after 3 weeks training, thats fine.
I've done the 2330 level2, 17th edition, I've took my 2391 and I'm half way through my 2330 level3 - I still wouldn't call myself an electrician (domestic or otherwise)
When I am completely happy with my competence I am going self employed - and not before. I still have a lot to learn.
The 'domestic electricians' reading this might be interested in a question we were given in college today - it might give a good idea of the difference in understanding dealt with in the two courses.
This is a 2330 level 3 question - it threw me for a while until I got my head around it:)
Mrs Jones wants a new cooker circuit installing for her 6 KW cooker.
The supply is 230v 50 hz. The ambient temperature is 35 degrees and protection is by a BS3036 fuse.
The cable is 70 degree thermoplastic pvc/pvc T&E, and is to be installed in earthed metalic conduit, buried in the wall, for mechanical protection.
The length of the run from CU to cooker is 30 meters and a socket outlet is to be incorporated in the cooker connection unit.
Volt drop must not exceed 6v.
Give:
Rating of the protective device
Conductor CSA of cable selected
Confirm volt drop is within limit
A nice little domestic scenario - might be your first job:D
Have fun,
Wayne
Looks pretty basic stuff really which is covered on all the courses debated on this thread.
Do you need any help with this homework or are you ok?
Hi,
Probably is basic to anyone used to cable calcs, but I'd say 90% of our level 3 class were struggling a bit with this, so I have my doubts as to whether anyone on a short course would grasp it that easily - I'd like to be proven wrong:)
I think I've got it now but, anyone wants to volunteer an answer, feel free.
I think the second part of the question asked what would happen to your answers if you swapped out the 3036 for mcb/rcbo instead.
Cheers,
Wayne
The first thing you need to calc' is the design current (Ib) of your circuit. So what have you got for this and how did you come by that value?
Why have you been given 6v for vd?
Hi,
I think it's just so that we get used to being able to check it - I know the regs would allow higher than that.
I doubt that the whole scenario makes sense - it's just to get us to practise the calcs, I think.:)
I remember touching on this when I did the 17th edition but it hasn't really been mentioned since - it's mostly come back to me now, but I wasn't joking about most of the lads at college struggling with it.
Wayne
Hi,
Wayne
Wayne,
I'm sure this is true but doesn't that kind of undermine the arguement about the 2330 college route being superior?;)
Anyway back to Mrs Jones' cooker, do you reckon it needs any additional protection?
Hi,
I don't know - this is what I'm trying to suss out - the levels of teaching in the different courses and the level of understanding that you come away with - I'm just going about it badly.:)
I don't think it undermines the course - It could be that the course is too difficult to be taken if you're not actually working in the industry - most of the lads at college aren't!
Sorry, forgot to answer your question,
I got Ib at 19.8A (after diversity) or 26.09A if your applying full rating.
So then selected a 20A BS3036
And yes, it would require additional protection because of the socket outlet, regardless of the cables being mechanically protected.
Cheers,
Wayne
Reply to Access 2 Tade Careers in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
My passat had an incident where Battery acid leaked and it damaged ABS Module, various light on dashboard switched on. Auto hold, cruise control...
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Electrical Courses
