Discuss Adding outdoor light to existing circuit in the DIY Electrical Advice area at ElectriciansForums.net
Nasko31
Hi,
I simply want to add an outside light to an existing circuit in the garage.
There is a single switch operating a ceiling light in the garage, would it be ok to change the single switch to a double switch to connect the outside light or is there a better way of doing that?
Please let me know.
hugo
Hi,
Please let me know.
hugo
You could do it that way assuming you understand switches lines and linking over the permanent line to the second switch.....unless it’s a switch fed circuit then you’ll need to identify the permanent line and link over and put the neutrals in together....got any pics of the inside of the switch?....isolate the power first ?
Assuming this is domestic the new light will require additional rcd protection if not already in place.
Hiya,
Thanks for quick reply.
I have a decent understanding of basic electrical wiring but never had to extend an existing circuit before...
That's what it looks like inside the switch (and yes I did isolate the power first ;))
Do I actually need additional RCD protection for this?
Hugo
To conform to current Regulations yes it will require additional rcd protection. There doesn't appear to be a neutral there and I would guess that is two way switching.
Reply to Adding outdoor light to existing circuit in the DIY Electrical Advice area at ElectriciansForums.net
I have a single wall switch powering 1 light and I want to add a separate light and change to wall switch to a double to power them both...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
We have an outdoor socket that is hard wired into the ground floor power circuit and protected with an rcd in the consumer unit. I now plan to add...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
