Discuss advice - two wall nights and one dimmer switch wired wrong! in the UK Electrical Forum area at ElectriciansForums.net
Long story short i had a friend helping me out with some DIY today and I have realised that he left the wiring like pictured. I have and voltage tester so i have worked out that the middle red wire is the live one.
Long story short they are now not working (i have tried some variations based on what i have read online but they just leave the lights on). I put them back to the way i found them wired - please see pictures (including the dimmer as i think he messed with that too. Can someone tell me what is wrong and how they need to be positioned/ connected?
and dont worry, i will never let him touch electrics again....
A competent spark wold have this resolved in under an hour.
I think I've figured it out but unfortunately explaining it falls foul of the forum "step by step guides" rule.
Also there are a few pitfalls with lighting circuits that mean it's not safe to offer diagnostic advice.
Generally the feed in should go through the switch then to each light fitting with the neutrals from the light fittings returning to the feed in neutral.
Your dimmer may need it's own neutral, note just because there is a black wire there it may not necessarily be a neutral, it could be an unidentified switched live.
And when someone has been in and messed the whole lot around it just becomes a PITA.
Thanks, I tried making a 'loop' (from the mains in to the dimmer, to the first lamp to the second etc) but it just stayed on. Tbh i am a bit tired, so i will give it another go next week and if i can't get it to work i might just get someone in. What confused me was when i looked online it suggested grouping the 3 live wires together but then i couldn't figure out how the light switch would act as the circuit breaker. :pensive:
This must be the most common fault I get called out for why does nobody make note of the wiring before they touch it, 5 minute job including cup of tea £30/40 notes depending on my mood
Several posts have been deleted advising which conductor to connect to which and whilst they may be correct we cannot be certain. The OP has limited electrical knowledge and the best course of action is to get an electrician in as suggested several times.
Thread closed.
Reply to advice - two wall nights and one dimmer switch wired wrong! in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
I have a led panel that i want to dim. It is dimmable but without a dimmable driver. I have a dimmer module and a dimmer switch as shown in the...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
Hi, Would like to change existing single pole light switch to attached dimmer switch. I have a live and neutral coming from consumer unit, and...
