- Reaction score
- 1
Recently notice a drop in performance of one of my heat pumps used for heating hot water.
The normal temp rise through the HP is around 8 degrees C but has recently dropped to around 3 degrees C.
The pressure guage shows approx 100psi with the HP OFF rising to approx with the HP ON but I don't know what the pressures should be but maybe these figures suggest adequate refrigerant in the system??
When I compare the 2 HP's when they are both running there is a noticable difference, namely:-
HP 1 condenser temp = 0 degrees C HP 2 condenser temp = 36 degrees C !!
other temps are:
HP 1 compressor out temp = 44 degrees C HP 2 compressor out temp = 46 degrees C
HP 1 NTC temp probe = 38 degrees C HP 2 NTC temp probe = 37 degrees C
Any suggestions?
other temps are:
Any suggestions?
