I am fitting a new light fixture. I have done one already and now on the second one. They are exactly the same.
It is a dimmer light. It has 2 lives, 2 neutral, and a earth (the naked wires).
For the previous light I simply swapped them all out for the new light and it worked fine. This doesn't work even though I've done the same thing. Before I shortened the braided wire, I tested it and it worked. Since then, I drilled the holes for the ceiling bracket and wired it in. When I flipped the switch, nothing.
I've tried testing another light and it still doesn't work. Is there someway I can test the wires? I have a multimeter but I am just a guy with VERY limited knowledge on these things so please be aware of this.
The wires seem to go into the block and fit well so I can't see what the problem is. How do I isolate the issue?
Many thanks
Many thanks
