Discuss Are surge protection devices fitted before or after the main switch in the UK Electrical Forum area at ElectriciansForums.net
What about putting it in the closet ?Hi L1Jay1 where do you think it should be installed?
I’m simply asking the questionHave a think about what the main switch does, and what it is for.
if you don’t know the answer, then maybe someone competent should be doing the work.
In the live boards the spd is before the main switchClearly 'tis the season to be grumpy!
How about you guys take a look at his profile and maybe go a little easier on him... it clearly states he's a trainee... just because someone doesn't have the trainee tag, doesn't mean they aren't.
@L1Jay1 , maybe consider signing up for the trainee section of the forums. You'll get a trainee tag so everyone can see you're training and you'll get access to a trainee only area which only trainees, staff and mentors can access so you can ask questions such as this without getting this kind of response.
To answer your question, they would generally be installed after the main switch. The ones in most domestic boards are installed as close to the main switch as possible, many are supplied via a circuit breaker (I've seen 32A for all the ones I've seen) but some, Hager I think, are connected straight to the main switch itself. But as @Strima says... what do the manufacturers instructions say?
What about putting you in the closetWhat about putting it in the closet ?
Hi - normally the main switch isolates all the equipment in the board, is that what you mean?In the live boards the spd is before the main switch
Sorry I meant a LVE board , I’ve seen a LVE board with surge protection already installed in it , the SPD is before the main switch in this board , this got me confused.Hi - normally the main switch isolates all the equipment in the board, is that what you mean?
Sorry I meant LVE board , not liveClearly 'tis the season to be grumpy!
I was trying to think of a way of wording that @DPG, stupid hangover! ?When you say the SPD is before the main switch, do you mean physical position or actual wiring order though?
This picture illustrates @DPG 's point perfectly. Physically it appears before if you're looking from right to left, but wiring wise it's most definitely after the main switch.
in LVE , SPD is before main switchWhen you say the SPD is before the main switch, do you mean physical position or actual wiring order though?
[automerge]1577093974[/automerge]When you say the SPD is before the main switch, do you mean physical position or actual wiring order though?
In the LVE board it’s before main switch, I’m trying to understand this and the way it’s wired, it appears to be wired before the main switch aswell.View attachment 54815
In that style of board the SPD is after the main switch. The meter tails terminate into the top of the main switch.in LVE , SPD is before main switch View attachment 54817
In the LVE board it’s before main switch, I’m trying to understand this and the way it’s wired, it appears to be wired before the main switch aswell.View attachment 54818
Sorry I’ve looking at this in the wrong way , the SPD is after the main switch and is pre wired , no need for over current protection , think I’ve got that nowRefering to your LVE board , The incomming tails would terminate into the top of the main switch, so the SPD would be after the main switch.
When SPD is after main switch and is pre wired , then the is no current flowing through it , am I correct .In that style of board the SPD is after the main switch. The meter tails terminate into the top of the main switch.
Ideally on an installation all consumer equipment should be after a main switch to allow for safe isolation. But if the supply was split before the main switch then the SPD would have to be before the switch as it is designed to protect the installation and not just the board..
With a lot of manufacturers if the main installation supply fuse (DNO) is below a certain rating there's no requirement for over-current protection for the SPD.
[automerge]1577099221[/automerge]
Its after the main switch in your picturein LVE , SPD is before main switch View attachment 54817
Nothing to do with CEF.CEF special I believe?
That’s what I thoughtNothing to do with CEF.
Before the main switch.Are surge protection devices fitted before or after the main switch
Reply to Are surge protection devices fitted before or after the main switch in the UK Electrical Forum area at ElectriciansForums.net
