R
Racing Green Bo
Hi all hope you can help.
My baxi 105e will happily run then stop with flame failure light. The actual problem is that the igniter is not working. I have discovered that when it trips out and after I have reset it and allowed it to run through its start up sequence it will still not produce a spark however, if I put my voltmeter probes across terminals 3 and 5 while it is going through the ignition sequence, it will guaranteed spark away and the boiler will happily run again for a bit. I realised this when going through the troubleshooting flow chart trying to work out if there was a voltage being sent to the igniter. This also works if I put the probes on the line and neutral of the ingniter unit.
Should mention have changed the PCB for a new one. Same problem which can be rectified with the same solution. For some reason bridging out the terminals with the voltmeter allows the igniter to spark. Ok for me to do to get it going again not ideal for the wife!
Cheers in advance
Cheers in advance
