V
volta
The circulation fan on my Beko oven works intermittently and gives a reading of 178 Ohms. I cant find a tech manual for beko oven fans so can someone tell me what the correct resistance reading should be.
Discuss Beko Oven Fan - Ohms reading. in the UK Electrical Forum area at ElectriciansForums.net
for £20 do they come as self-assembly as in your pic., or are they ready built? :indian_brave:Is it a shaded pole motor like this
its identified with the copper bands around the laminated frame. If so and the coil is giving a reading I suspect its ok. even if this motor is stalled for long periods the windings will not burn out.
Check the bearings and for the fan fouling the frame as wirepuller has already said remenbering heat can affect bearings too. Telelectric has given the other option above.
If its the motor these motors are very cheap around £20 last time I got one from Espares.
Reply to Beko Oven Fan - Ohms reading. in the UK Electrical Forum area at ElectriciansForums.net
