Discuss boiler control pricing?? in the Central Heating Systems area at ElectriciansForums.net
Varies. i always survey my boiler jobs as is never straight forward or consistant. Every boiler control job is different unless your doing an estate or flats.
Spud
Gota ya!!! but just a rough estimate for a straight forward y plan, cables already in just new stat time clock new valve?
estimate how long it ll take (in hours), multiply it by your hourly rate and add materials costs, certification cost, Part P notification costs and VAT if applicable and you have your answer my friend.
Reply to boiler control pricing?? in the Central Heating Systems area at ElectriciansForums.net
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
i , i have a property to work on which has a programmable room stat upstairs and a programmable roomstat downstairs. S plan system , 2 zones. hot...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
