Search for tools and product advice,
Discuss Broken TT earth cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dismal
Can I have some thoughts on a broken TT Earth. The house owner has cut through there TT Earth cable 3 feet up from the stake.
Can this be jointed and if so what would be a suitable connection, in an ideal world a new continuse cable would be preffered or is this the only option. I could not see anything in the regs to say this cable must be continuse or was I having a Man look as my wife refers to it.
Many thanks
Daniel
Acceptable methods of jointing it would be to crimp or solder
As you say a new lenghth of cable would be the best option but as long as the joint is free from becoming corroded I see no reason why not
Covering the joint in heat shrink sleeving should be adequate,allthough I believe a sheathed earth cable should be green/yellow throughout its length
The joint could also be enclosed in suitable plastic conduit if possible
Reply to Broken TT earth cable in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Carrying out a EICR in a commercial setting. In the main intake room the DNO supply comes in and it states clearly this is a PME system. 5 years...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Afternoon all I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system. Current issue is earthing...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
