Discuss Cable bending radius in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
laxmi
Hi,
Is anyone got a table that shows minimum bending radius for cable. I wanted for HV armoured cable bending radius calculation?
Regards,
Laxmi
mache is correct iv,e checked 2 cable suppliers and come up with 14 times & 18 times the diameter so it would be best to check with your cable manufacturer
Reply to Cable bending radius in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
Hi, someone has ordered Steel Tape Armoured cable instead of SWA. Can I use this armour as a CPC the same as SWA or not and if so is there a table...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
